EVGA 8800GTS-SSC Power Question
NauticaONE
in putting together a new rig, I ordered a Raidmax RX-630A (630Watt PS), which I thought would be enough power for everything I have going on , but while putting together the components, I read on my EVGA 8800GTS SSC that 24amps (24 friggen amps?) is required to be on the +12volt Rail for the card to function within limits. Looking at my power supply ratings, it shows that the +12volt is supplied with 20amps for a maximum current limit.
Now my PS3/50" Plasma Display use a grand total of 6amps when at full blast (all white screen) is this something I can just brush off? I dont think its a show stopper, just wanted to make sure im going to be ok within power bands.
While Raidmax is not the epitome of power supply quality, it should be sufficient for the video card in question. The PS has two twelve volt rails. If you list the rest of your machine, we could assist you more efficiently.
+12V1@18A
+12V2@16A
Remember that your 50" display operates at 120 volts. When you reduce voltage by a power of ten, amperage goes up by the same multiplier.
Research, research, research.
Yep as above you will be fine as it has 2x12V rails
I run the Raidmax 550watt model with 2x12V rails fine on a 8800GT. The video card itself does not need 24 amps, the rating is a rough guide for the entire system so add the rails together.
Not the best PSU's on earth but they are ok, seen worse.
Thanks for the update, here is the rest of my rig (being built)
Q6600 G0 = CPU
Asus Maximus Formula = Motherboard
WD 250 GB SATAII HDD = Windows HDD
WD Raptor 74GB (old version) = Games HDD
EVGA Video Card (mentioned previously) = Display adapter
(qty 2) pioneer 16x dvd-/+ r drives = Optical Drives
Antec Nine Hundred = Case
1x200 mm fan (top of case) / 5x 120 mm fans (including the one for the CPU)
I bought the raidmax because newegg was marketing it pretty good, and it was modular, and didnt make me have to refinance my house to buy it. in hindsight I should have bought a better PSU, and maybe I will,
if someone would provide the following recommendations I would appreciate it
1. Keeping my Existing PSU, how should I split the devices between the two 12 volt rails?
2. Purchasing a new PSU, please provide model recommendations short of a 1000 watt SLI enabled PSU (not planning on running sli or crossfire).
Thanks in advance
If you already have the Raidmax, there is little reason to return it unless you can do so for no restocking fee.
Great deal on Antec 900 alternative.
A safe bet would be a Corsair HX-520/HX-620. Also consider Thermaltake Toughpower & Silverstone ST60F.
I would not put that kind of quality hardware on a Raidmax PSU, they're crap in my experience. Go with some of the suggestions above, the Corsair PSUs are really good.
its getting returned, 15 dollar restocking fee, but id rather have that then a mess on my hands regarding power. ill be ordering that corsair psu.
Thanks
