EVGA 8800GT Woes
wee96
Great, I just got my Step Up card, 8800gt 512mb and it does not display via DVI whatsoever. Itll display analog but very crappily, and is making me very angry since ive been without my card for so long and now I have to pay to ship something that doesnt work and wait AGAIN. It would be nice if an EVGA rep could help me out on here, whenever I try contacting them via email I never get a response.
Have you got another DVI monitor to try?, two cards seems unlikely, seems more likely you are missing something.
New Dell lcd, my 8600gt works perfectly fine in the same system, and 7900gto before that.
That sucks but we all get lemons, hopefully it will get resolved quickly. I love mine its a nice jump from the 7950GT I was running!!
Have you tried putting the card in another computer? A friend's machine?
I am sorry that your videocard is not working. I believe that i have found the issue when inspecting your system specifications. You have a 460 watt PSU with 20A on the +12V while the minimum required to run an 8800GT is Minimum of a 400 Watt power supply with
(Minimum recommended power supply with +12 Volt current rating of 22 Amp Amps.) While your PSU seems to be very close in specification it could be the reason why two cards in a row are not working in the same system, as your PSU gets older i can handle less and less of a load and i have a feeling that it cannot handle your videocard. The reason the 8600GT worked was because it only requires 18A which your PSU does support. If you continue to have issues after getting a new PSU please feel free to PM me.
Thank you and have a nice day,
Anshel Sag
Anshel Sag
My power supply has 22a on each 12v rail and puts out a combined 32a. This has nothing to do with it. Not to mention the card DOES display via analog, but does not find the monitor properly and cannot do widescreen resolutions.
Try isolating the video card onto its own power rail if you haven't and unplug any unnecessary components. Remember your PSU looses efficiency over time, and might not be hitting 22a on the 12v anymore.
EVGA will happily help you out if your having more problems. If you ask and say its a second time shipping it back, they may help with shipping, you never know. They do have great service after all. =]
Try isolating the video card onto its own power rail if you haven't. Remember your PSU looses efficiency over time, and might not be hitting 22a on the 12v anymore.
EVGA will happily help you out if your having more problems. If you ask and say its a second time shipping it back, they may help with shipping, you never know. They do have great service afterall. =]
I havent gotten a single response from them.
Hmm, give RussianHAXOR a PM then. He will help ya out, he might be a little busy tho, so might not be instant responces.
Yea im going to, I really dont think I should pay to ship it back after ive paid for shipping twice. If it were the power supply, the card would not display in vga mode and it does. I didnt mention that my step up card was a 8800gts 320mb, which worked fine and if im not mistaken used more power. Its no doubt the card, and is angering me.
If your card is obviosly not working in several machines why are you even asking what to do?
Surley if your card is faulty you will need to rma it.
I was asking if someone knew of an issue that maybe I didn't. I stated before, the card works on analog but not properly so I was hoping that there was something to fix the DVI issue and there is not.
I have an 8800 GTS 512 MB that I just got that does not work in my 680i board with an Enermax 1000 Watt PSU. I grabbed the spare 1000 Watt I had, and it works fine. Interestingly enough, the Enermax powers 8800 GTX SLI just fine. There is a voltage variable somewhere that these new cards do not like. I even swapped the 680i boards between systems to try and no go. The PSU is the likely suspect no matter what the spec is.
And, like you, the card works only in VGA mode when it was having issues. Once the drivers are installed, the system boots, beeps and then no picture. On the occasional time it did work, I would see the NVIDIA power sentinel indicating insufficient power for a flash of second when the system was shutting down. To even get a VGA screen with DVI, I had to remove the NVIDIA drivers completely and reset the BIOS configuration data (there is an option to reset with each reboot) for the card to work with the bad PSU.
Its worth a shot, thanks for the idea im going to try it.
