Took off default HS&F
Purchased:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186016
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186021
Used ArctiClean to remove stock paste from new Cooler linked above.
Applied Arctic Silver 5
Did not use any RAM Heatsinks on the card.
Used NiBiTor to get Volt to 1.1
Used RivaTuner to OC to following clocks:
756 core
1836 shaders
1000 mem (2000 ddr)
Idle Temp: 38 c
Load Temp: 47 c
3DMark2006:
12875 w/ Core 2 Duo E6400 @ 3.2ghz (stock cooling), 2gb RAM, XP Pro SP2
Purchased:
756 core
1836 shaders
1000 mem (2000 ddr)
Idle Temp: 38 c
Load Temp: 47 c
3DMark2006:
