eVGA 8800GT $260 @ Newegg..
Fel
Should i go for it? I'm planning on building right after Christmas..
If its the EVGA 512-P3-N801-A1 it has the older cooler so I would pass personally.
I Just noticed that.. but for the price, and the eVGA warranty..
Besides, didn't they stop production of the old fans?
edit: its not that specific model, the superclocked edition has A1 too, they just probably havent updated.
I just looked at the one that was $259 and some change. Just going by the photo (not always accurate - the Asus one is all wrong) it looks like old cooler with louder fan. I would wait for a revised model. Maybe the memory modules will be better too - that's another post.
Looking at Newegg at night I find a lot of the out-of-stock models show up then. Almost every other night I have have seen one sold out model or another show up just to be sold out by mid morning. I'm sure you wouldn't have to wait long if you keep at it.I bought the XGX 8800GT when it came on at 2 AM one night.
What would you recommend i buy?
I was going to get the BFGOC from bestbuy for $280, but then i saw this one come in stock and i donut know what to do..
i got the A1 version last wed from newegg and its the old cooler dont know if they are the new ones yet
guys...dont place any faith in the item pictures or specs on Newegg...they are known for being very wrong...look at the part number, look up the part number on the manufacturers website, and order accordingly, if you happen to get the older stock i am pretty sure you could RMA to the manufacturer and get a current stock model, but at the end of the day, if you buy EVGA or XFX and register it properly, does it even matter? you have a lifetime to use it worry free;)
how loud is the old fan when turned up? I'm not nitpicky, but i have my boundaries.
I have an older fan on mine, but following this guide:
Here's what you do:
Use RivaTuner 2.06
Power user>RivaTuner/Fan>open it by clicking on the + box to the right>AutoFanSpeedControl,highlight the check.In the right hand box,double click and put in the number 3>apply>OK..................
now exit and reenter RivaTuner.
Main Tab>Customize box under Target Adapter>Open this>Select the GPU icon(first one)>enable low level fan control>select AUTO>here are my values for my 8800GT:
Duty Cycle min:45
Duty Cycle max: 100
Tmin:60
T Range:32
T Operating:78
T low limit:55
T high limit:92
You do this by clicking in the right hand box and editing the number that is there to these values.
Next check apply at windows startup,click save,click apply,click OK.
Exit RivaTuner and reenter.
You should now have an Auto Fan control that changes the standard low Nvidia fan settings and runs the card much cooler. It will be a bit noisier.
I have no qualms.
So what's the deal with this older cooler shenanagins? I grabbed one of these A1's while they were in stock at newegg. Is the fan just louder than the new ones? Are the cards the same otherwise. I don't plan on overclocking this card but I might play with it a bit. It's more of something to hold me over until I step-up to a 9800.
Do you think i can overclock it to at least 700Mhz on the old fan? Does eVGA cover OC damages?
so all of sudden because its the old model no one wants it...
SOB's !!
ya im curious about this. i JUST got one from newegg when they just came in stock yesterday night. On my paper from buying it is says its the A1...but people have been saying newegg is known for misprinting things. i dont care that much..but 2 questions
What is the difference in the coolers? is one just lowder and the new one is quieter or what? and second, does OCing the Vid card void the warrenty?
I have a feeling regardless of what the site says it's going to be the newer cooler. If they just received stock from evga it will most likely be the new one. I'll find out in a couple days I guess.
