I have a few questions about this video card...
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130333
I am using an LCD screen which is optimized for a 1360 x 768 resolution, does anyone know if this card can display that resolution ok?
Another question, my screen has 1 VGA input and 3 HDMI inputs, what do you guys recommend doing?
DVI to VGA adapter and use a VGA cable (or vice versa)
HDMI to DVI adapter and use a DVI cable (or vice versa)
or even using the HDTV cable that the card comes with and plug it into a Component in slot
