EVGA 7900 vs 8800...
Skooongie
I don't plan on upgrading my system for a while, since it works fine. All I really play is CSS and watch movies.
Would a 8800gt...? be a reasonable upgrade to get? They are so cheap right now.
Thanks guys.
About 100% increase in performance with the right CPU. With your CPU it will be a lot lower though.
So long as it's a 512MB version, though your P4 is going to be a huge issue in anything that isn't heavily GPU-intensive. Depending on your settings you may see zero framerate increase in CSS, even.
Look on the forums here and try to grab an HD3870 for $60 - $65 shipped. That would at least get you better performance now that would burry your 7900GT and isn't too far behind an 8800GT anyways.
