Evga 7900 GS any good?
I have one for about a month now.
it is a hell of a card , amazing plays all my games .
TOCA , NFSMW ,FIFA 2007 .
all maxed and other games with 40-60 FPS.
it is a hell of a card , the only advice i can give you .
there is a 20$ more expinsive version that supports HDPC , don't know what that stands for.
but you are better buying one that supports it.
ooh and it is amazing with Vista.
another point , if you are gonna overclock get a good fan.
the stock is amzing but the card gets hot on OC'ing
HDCP is a coding for HD Movies allows you to decode the HD Code.:D
And yes, this is a very nice card.
mine says it supports HDTV , isn't that the high difinition vedio support ?
Depends on if they are protected with the HDCP key, also you may need an HDTV decoder program.
You can install a HD decoder to watch HD movies...Some burning programs have HD decoders...
no, its in the hardware.
the 7900 gs series typically can overclock VERY well, to getting near the 7900 gtx in performance.
I just got mine in tonight. EVGA 7900 GS KO, I have a A64 3200, 2gigs ram. So far BF2 runs great cranked all the way and LOTR online runs the same. Im gonna load up NFSMW and Fear tonight,(games that killed my 6600GT) and see how they do. I post back up when i do.
Edit: hello hard forums!
Does that mean the 7900gs is better than the 7900gt since my gt can only reach 518/780 w/o a voltmod?
Mod for evga, and doesnt even know High Def Copy Protect. :rolleyes:
I dont? :confused:
HDCP has a key that allows you decode HD movies... movies that are protected require an HDCP key that can be invalidated if piracy is detected.
Without HDCP you cannot watch some movies....
I'm sorry if i was too vague.
700? dam. What kind of FPS increase could you get OC this card that much?
I'm in the middle of another cross-shipping event through eVGA with another 7900 GS KO. So, at least to me, they aren't all there cracked up to be. IMHO. Plus the fan noise is ridiculous.
Tho, I can very much appreciate eVGA's customer service.
I game at 1600x1200 BTW.
I game at 1280, and it wasn't a huge step up from my 6800 Vanilla. I eBayed it and went with the GTS640, couldn't be happier.
I have an evga 7900GS KO.... it's running at 575 mhz without any problems at all. Couldn't be happier with it
well as for the speeds you guys are talking about the XFX 7900 gs Triple XXX edition is factory oc'd to 600 and 1630. It has come down to under $160 after mir. As you can see by my sig what performance increase could I expect from one card vs my weak sli set up? I play source games hl2 dod:s tfc .
A 7900GS beats a pair of 6800GTs in SLI, and the 6800GT was a fair step up from the 6600GT.
I ran a 6600GT by itself, heavily OC'd. My HL2/ CSS fps increased when I went to a 7600GT and again when I went to the 7900GS, and I could use higher AA/AF and HDR became useable.
