EVGA 780i Microphone on Win10
TeleFragger
Ok wasn't sure where to put this.
I have been running windows 10 on my surface pro 2 and my gaming rig (yes very old now)... has been sitting.
I just fired it up and installed windows 10 - 10162. Windows installed all drivers and all seems fine. I couldn't get my headphone/mic combo working so I went to realtek and downloaded their drivers. All good with sound but I cannot get MIC working... I am going to start playing games with the guys and they use Ventrilo for chat so I do need the mic.
any thoughts on where to start?
what I did..
1. tested headset on a different computer and works.
2. on other machine bring up audio devices and where it shows Microphone with a check... and when you talk you see the little bar go up thus sound...
on win10 pc... I plugged in mic and it stated it was plugged in.. thus detected. I go in and it too shows a check.. but when I talk no bar moves...
tried sound recorder and nothing... no sound...
thoughts? gaming in 9h
going to try the drivers from 2012 for the actual mobo.. will see but I don't think that will do it...
and fyi previously this machine worked fine.. with this headset.. and also I tried the rear plugs (as right now I'm using the front ones) and same thing...
My 780i on w10 works fine with regards to the mic with the same windows 7 drivers it had before. Just to let you know it works.
even weirder.. I went back and installed windows 8.1 and cant get mic to still work.
so tried front jacks and jacks back on the motherboard.
I have a Logitech G510 keyboard so even used the ports on the keyboard... sound works but no mic again... wth!!!!!
so one would think it is the headset but I went back to the other computer and headset works....
im lost... maybe ill go pickup a new usb headset today...
well im thinking it is the mobo and a new usb headset would use the onboard mic thus issues... sooo i gotta figure out if Bluetooth headset uses the on-board chipset
USB headsets typically have their own sound chip embedded in them so that they appear as a separate selectable sound device (I've never seen one that didn't so far) independent of any other sound source in the PC. You should be fine with one even if the on-board is flaking out.
thx i got the logitech 930 and LOVE IT.. wireless and ties into the SW for the logitech 510 keyboard i have... well im good to go and been gaming!
