eVGA 7600GTS
ep1taph
http://www.newegg.com/Product/Product.asp?Item=N82E16814130054
This card is not listed on eVGA's own product list.
It appears to be a 7600GT. The clock speeds (560/1400) are those of a 7600GT, and I assume it has 12 pixel pipelines. It used to be listed in the 7600GT category, then was moved to the 7600GS category. What is with all those extra caps?!
It really appears to be a 7600GT, and for $109.99AR. That's a good deal.
Anyone have any more info or insight on this card?
It's a 7600GT but it only supports software SLI and not hardware SLI. It also seems to only support up to 2048x1536@75Hz whereas most 7600GT cards support 2560x1600.
I suppose the S may be an indicator for the software-only SLI mode.
The resolution limitation is odd, but noted.
Thanks for the reply.
