eVGA 750i Data Corruption
LittleMike
Hey all,
For any of you that have been following my other threads, you know that I have taken the route of the 750i chipset mobo. Well the build is finally up and running with Vista Ultimate 64-bit edition. However I've run into some interesting problem. I keep getting random data corruption on different files. A chkdsk will usually fix it, but then some other random file will break (sometimes even the same one). Is this the infamous data corruption that people say have plagued the 7xx chipsets? Is there any workaround? My current setup:
eVGA 750i FTW mobo
Intel Core2Quad Q6600 2.4GHz CPU
2x2GB of OCZ Reaper HPC edition DDR2-800 RAM
2x 750GB Samsung F1 SATA 3 drives in RAID 0
2x eVGA 8800GTS 512 (G92) in SLI
Any help would be appreciated. If this is due to the nVidia chipset, will a 3rd part RAID card fix the problem? Hell, I'll consider just using one hard drive as a main drive and the second one as a backup drive at this point. I'm at my wit's end. :(
Look on the evga forums. It is a known issue. Their last bios release was supposed to fix it, but it didn't, so now they are saying the next one will.
I did look on the eVGA forums. The corruption they were talking about, though was video corruption, not data corruption. I even saw some threads with screenshots of lines going through the screen. The new BIOS release has fixed it on 9800 series cards, but not 8xxx series cards.
That's not what I'm talking about, though. I'm talking about data corruption. As in, I will open an mp3 and Windows Media Player will crash. Then you check in Event Viewer and it will have an entry saying that it crashed because it couldn't read that mp3 file. I'll run chkdsk and I can open it again but some other file will break.
Also, the graphics corruption only seemed to apply if you were overclocking. Some magic ratio that would cause graphics to corrupt/artifact/tear, but if you went higher or lower with your OC, it would be fine. Again, that's not the same issue I'm having.
EVGA 750i FTL!!!
Sorry I just couldn't hold it. :eek:
Haha, well if it is indeed caused by the mobo, then I definitely agree with you. My problem is that if it is the mobo, then what am I going to do to fix it? Get a separate RAID card? Forego RAID all together? Dump the board, sell a video card and go X38? :p
As stated, that is video corruption.
Did you try running your system with raid 0 disabled? That might be the problem.
I don't understand what you mean. How can I run it with RAID 0 disabled? Then it wouldn't boot. I have the OS and everything else on the one RAID. See the specs posted above - 2 Samsung F1's in RAID 0
