EVGA 7300GT Trouble
ste4en
I have had the EVGA 7300 GT in my computer for about a year. On an Abit FP-IN9 MoBo (no onboard graphics) running Vista. I use a Zalman ZM80A passive heat sink, I don't play games; do a little with photo shop. I have a DELL UltraSharp 2005FPW which runs on the output from the VGA.
All has been well until this week when I am getting a lock ups (screen with a zig zag pattern) every few hours of use no particular pattern of when it occiurs. I added a cooling fan and left the box open and still get the problem. I removed the VGA card reseated it and reseated the passive cooler, I updated the drivers too, no change.
How can I diagnose the problem,do I need a new VGA card.
added ........I just left it with the zig zags and it eventually restarted itself...maybe this is not a Graphics card problem.
Thanks
Ste4en
The first 2 things to do would be to reseat the graphics card and get better cooling, but you already did those =)
I would start by putting the card in a different computer to see if the problem reoccurs. If you don't have an extra computer lying around the house take it to computer repair shop and ask them to try it, although they will probably charge you. If it works fine in a different computer, you know that the problem is isolated to your computer.
If there is something wrong with your computer alone, and if you have a same-socket computer at home, begin by disassembling your computer and troubleshooting each component in the other computer, this will let you see where the problem is.
If it turns out that your video card is bad, then luckily for you now is a great time to buy one. I would reccomend going with an 8600GT, which will serve you well for your purposes, while adding dX10 support, for only about $90. http://www.newegg.com/Product/Product.aspx?Item=N82E16814150265
thanks for your response.
I dont have nother machine or access to another card without buying one. Today I found an analogue cable and connected to my monitor through that. Since then it has not crashed once even when i switch back and forth between dvi and the d-sub,
I will see how it goes over the next day or so.
