EVGA 680i Ram comaptibilty Question
Loshki
Hey, this is my first post, so hello everyone!
I am going to build my own PC and i've already done a lot of research. I've decided to go with the evga 680i for SLI compatibility and e6600.
Does any know if this RAM
http://www.newegg.com/Product/Product.asp?Item=N82E16820144034
will work with the motherboard? I've read about some voltage issues with this mobo.
Secondly has anyone had any experience with this RAM? I could not find any reviews on it, so I don't know whether it is good or not.
Thanks
I am having problems with my ram and its the second pair I have tried and 3ended up taking them out.
Just got back from a trip and will check if there is a bios update. First pair I used was supertalants ddr800 and then got some memory error and had to switch it with corsairs , after two weeks got the same problem again so now its running on 1 stick.
