EVGA 680i Post Problems
Endrithius
So I recently rebuilt my machine. I have been wanting to build the new machine for a while now but took my sweet little time plotting and planning and thinking and dreaming. I still have a few more steps before I am done but for now I have the "new" machine up and running. After lots of planning I decided to go with the EVGA 680i motherboard for my selection, with its 680i chipset and 3 16x slots (one of which is actually only wired for 8x) onboard raid ran through the pcix bus instead of the pci bus - and the fact that its effing hot!
Picked one up from Fry's for $225! At the time it was going for $300 and I was excited until I got home.
Once I got home I installed the board - as well as the mounting brackets for my ThermalTake BigWater SE water cooling block - which is quite a bitch I might add - got everything else installed and booted up. Power came on - all the fans turned on and I was happy - until I noticed that the on-board diagnostics LED readout said -- and there was nothing going on. No video - no beeps - nothing. So I systematically took everything out. Ram - Video - Sound - HD's DVD rom's - none of it worked. So I unplugged every un-necessary connection to the motherboard. I even unplugged the power and the +12vx8 connection - and started those over - reseating the power connections and then using the handy dandy on-board power buttons on the mobo to turn it on - same - damn - thing.
Called EVGA (by the way its now 3 am in the morning). SOMEONE ANSWERED! I am impressed. Very. He was helpful - he asked the obvious questions but never pestered - after I informed him of all the troubleshooting I had already performed he moved right along. No making me do everything all over again. At this point he left me for about 2 minutes to go check some troubleshooting logs - I felt the need to make a late night/early morning quesadilla - after coming back he had said something though that made me think - he said "When these boards come back its always one of 2 problems - either the BIOS chip is bad or the RAM was bad and they test fine for us." So I informed him that I was going to finish my quesadilla and go to bed and that I will return the board in the morning to the Fry's from whence it came. He told me that that would be the best idea as the RMA process from the manufacturer took a few weeks and it wasn't a guaranteed new board - they MAY send back the old board if it posted fine at the office.
To bed I went!
When I woke up the next morning I found my roommate working on it - my friend had been awake all night playing some Battlefield 2142 and had seen my roommate come home and told him that my new pc was borked. So Erik went to work - digging and doing all the same things that I had done - but here is where my mind came to work - the board isn't posting - and Erik already had the entire thing out of the case - lets try posting it outside of the case - by the way because all my watercooling was already installed and the hoses were cut to length - this was quite an interesting job - as things had to be held in a very unnatural position - anyway - outside of the case - life is good and the board posts - WTF?!
So we look in the case - I have a P180b - nothing wrong there - nothing to ground the board out - but looking at the back of the board - there were 6 HUGE soder points! These things were enormous - easily long enough to touch the mobo tray - I had never seen anything like it in all my years. So - armed with my trusty pair of dikes I clip them down - and for safe measure I install a bit of foam between the mobo and the mobo tray - BINGO! It works!!!
Basically these sodder points are located at each of the large coils you can see on the top side of the mobo - if you look on the bottom side you will see 2 sodder points that hold those coils on - there are 3 coils - clip/shave the points on the bottom and there you have it - a perfectly working 680i mobo.
nice thanks for the heads up.. got my evga 680i installed no problem...
but i was kinda stupid.. i flashed the bios right away to P23.. from P21... since i wanted to latest and the bestest bios.. but this bios was unstable.. kept on crashing.. and freezing even in the bios menu.. i even did a cmos reset after i flashed it no go... to make a long story short.... it even frooze my reflashing of the P23..so i thought i was screwed.. but flashed my board to P21..and all is good! very stable bios.. just wondering why i cant flash to P23?? weird...
Can some one please post a link to the P21 Bios, or Host it? Please i wanna try that too, i am having problems with all other BIOS.
I am having that USB bug Issue some times. Even i flashed to P24 BIOS, and some times system won;t post and stuck during start. I have to reboot couple of times to go into windows.
Some times, there are some random beeps, then i shut down computer and restart again multiple times until BIOS reset and it runs with the default speed.
What should i do?
