evga 680i Northbridge Cooler Question
vanilla_guerilla
when you removed the northbridge hs to clean it off and reapply as5, did you remove the foam strips that were around the edges? i guess they are supposed to keep it level, but mine is slighty cocked back towards the cpu. if i put a little pressure on the front of it, the temp in bios drops about 12F. tried reseating it just now when i replaced my cpu cooler and had the board out, but it didnt help.
