Evga 680i eSATA trouble
anonuser
I can only get the eSATA working on my 680i board if I have the external harddrive on from bootup like a regular drive. If I turn the external on after bootup, windows doesn't see the drive.
I enabled eSATA on the sata port in bios, but still I'm having the same problem.
I am plugged into the bottom ports that face out to the right of the board and I enabled both of them just to be sure. Maybe the information I have on sata #s is wrong?
Does anyone know what each sata port is labeled in bios? Or know what I may be doing wrong?
Thanks.
the vertical are 1 & 2, the horizantal from power connector toward opposite end are 3,4,5 and 6
I am running vista and using eSATA features and as soon as drive is turned on, vista pauses for about 10 seconds then recognizes the drive.
the manual shows what each port is numbered as and you have to set the bios to each one you want as eSATA.
Yeah, but in the bios they aren't numbered 1-6. I'm at work right now so I can't check.
I must have that setting wrong...
