eVGA 680i CPU support
BinarySynapse
Ok, here's a odd one fo you guys. I need ot know if an eVGA 680i motherboard will support a Celeron D cpu. I'm ordering parts this week and wanted to get at least the motherboard I wanted for now and slowly add the rest of the components I want throughout the next few months. I know some of you will think it's a waste of a good motherboard to put a Celeron D in it, but it will eventually be used how it was meant to. So what do you say, will it work?
sweet, thanks. I didn't even consider checking Nvidia's site. Now I can get the board I want now and the processor I want later.
Kudos to you for having the brass nads to drop a Cely-D on that mobo. :D Hopefully the eVGA 680i owners here will understand and not boo you off stage! ;)
Well, it's either that or spend it all on a 945P motherboard and a P-D 915 with no option to upgrade to the Core 2's. So....at least this way I can drop a Core 2 Quad in it when I save up some more. In the end I get the system I WANT, and still save a bit of money by not having to blow it on a temporary fix that I probably won't get much return on.
ugh, after doing my usual cram seesion of researching parts that I always do as the ordering day gets closer, I don't think I'm going to risk buying this board. Back to Asus P5B-E it is. Oh well.
I am getting the same motherboard, but i was wondering if my Pentium D smithfield 805 would be compatible with it, since it is 533 mhz FSB. :confused:
If the Celeron D is, then the 805 will be too. They both have 533FSB's
