EVGA 680i 1T 2T Problem.
orion23
Hi!
I was running a stable setup using an E6400 @ 3.52ghz and 1GB or PC2-6400 @ 880mhz using 4-4-4-12 and 1T settings
I upgraded to 2 X 1GB Crucial Ballistix PC2-6400 4-4-4-12 but now I cannot use the 1T setting anymore, not even @ stock speeds.
Windows will not boot, or it will freeze @ some point before the desktop.
@ 2T things work just fine @ 800 or 880mhz!
WTH!
I found that I couldn't get 1T on the 680i as well. I have a thread about somewhere around here. Basically, it's pretty standard on these boards. Though I can't explain why you were able to do it before.
The only thing I see similar between us is that we both are using 2GB. Whereas you were at 1GB previously.
Thanks....
This brings back memories from the AMD 939 4 RAM sticks and the 2T limitation....
Yeah it sure does!
I'm having the same issue. My last board would run these sticks at 1T, but the 680i doesn't want to.
You know what though? I haven't been able to see a tiny bit of difference in benchmark scores running 2T. Maybe I'm not running the right benchmarks (lol) but if I can't notice a difference, I'm not inclined to care.
I've heard that the 680i won't go over 400 (x4:p) mhz on the FSB and still be able to do 1T reliably. I'm too lazy to check if 1T is stable at 400 mhz because I'm loving 450 FSB too much!
I am running a 440 FSB and wish to take it to 450mzh for a 3,6ghz overclock.
We'll see how that goes!
the same as the other guy. i used to be able to run my g.skill hz d9 at 1t up to around 880mhz, but as the bios updates came along it doesnt do that anymore. it will only run @ 800 with 1t, and the board isnt happy about it either. but like the other guy i havent seen any difference in superpi times, 3dmark, etc between 2t and 1t. i dont get much difference between cas 3, cas 4 or cas 5 either. a little, but not much.
