I bought an 680 SO Sig+ from a member a week ago. The card ran just fine - no problems at all. I decided yup to try out an accelero turbo plus ii on it, so I threw it on. Notice I have installed and uninstalled many, many arctic cooler gpu heatsinks over the years. I am very meticulous about making sure everything goes right.
Anyways, I found that it didn't help out the temps very much-mostly because of my case- so I decided to take it off. Everything had been r running just fine. I cleaned everything, and put the original heatsink and shroud back on. I go to plug everything back in and when I turn on the comp, the fan turns up to 100%and stays there and there is no display output at all. Clearing the cmos and Updating the bios doesn't help.
I threw in my wife's gtx 460 and everything boots up just fine. I put the 680 in her comp, and the same error occurs. I took the heatsink back off and inspected everything and it all looks totally fine. Put everything back together, still the same problem.
Any ideas? Thanks guys!
