EVGA 680 Sli problems..
slunge
Morning All
My EVGA 680i Sli is giving me supreme problems.. it goes a little like this:
PC Built - runs sweet as a nut for over a year
PC Started blue screening while using my overclocked C2D 6420 @ 3.3 ghz, down clocked to stock speed - still giving me problems.
Run a few tests, after a while the Problem just dissapears - install Q6600 CPU, upgrade Bios to latest on evga site.
Problems reappear - but also now with cold boot problems (motherboard stops at searching for Hard Drives, sometimes just hangs without any text, boots to windows XP boot screen then restarts, also bluescreening in windows with "IRQL not less or equal" screens, various services - ntfs, tcpip etc etc...)
I run memtest x86, 24 hours pass - reecheck all connections, reseat memory and gfx card - eventually problems dissear for 2 weeks...
Last night, CPU giving me real problems, one blue screen, on restarts PC is hanging again (Sometimes giving F0 on error indicator) - occasionally gets to memory check / windows start and hangs - only fixed by leaving the PC off for 30 minutes with mains disconnected (and this only gets it back in to window temporarily).
Tests run, memtest X86 (pass), quad core orthos test (pass), Western Digital HDD tests (pass both drives) - and when its running sweet (bear in mind its default speeds) its great, not a bother - playing quakelive for 4/5 hours steady, then suddenly from no where problems kick in again.
Has anyone got any ideas I can try... im really running out - and coming close to trying to buy another motherboard (this is far from ideal.. im skint).
Cheers
S
Sounds like an RMA is in order. My guess is the northbridge. Try this: downclock your system (i.e., lower the FSB, lower the FSB, Northbridge, and CPU voltage) and see if you get better/consistent stability.
Side note, I went through 2 680i's and 1 780i before giving up and going Intel.
I love my EVGA 680i SLI SE board(the one that can't OC quad cores). I guess it just depends on when you buy it. I also never OCed on mine.
Thanks for the reply's
Problem is I bought the Board like 20 months ago (was given to me by one of my suppliers from work, bought brand new from overclockers uk) - not sure if im going to be able to RMA this dispite a lifelong warranty?
I have reset the bios a couple of times (one of the lockups required it for me to even get back in) and also did that when upgrading to latest bios.
I may drag it all out the case and refit everything to make sure theres no grounding issues although nothing has changed from when it was stable so im not sure how much it will help
Thanks again
A
Thanks again
A
newegg listed the board as having a 1 year warranty, which i find hard to believe since it was a flagship board not too long ago. also, try calling their 247 tech support, they are awesome. 888-881-3842.
i had booting problems b/c the back panel of my case would pull my video card just enough to cause it not to post, and that took me a couple weeks to discover. might want to also try a diff psu, a faulty one can lead to irregularities and crashes
Hmm - i thought some places might say that about their warranty however as i remember there were two board revisions - one had lifetime warranty (mine), the other 1 year (diff codes marked on the boards) - funnyily enough i have thought about giving a new PSU a go, only problem is I bought the ram, cpu, psu and everything else together (so psu is 18 months old i guess) and I dont have another 500W + PSU anywhere.
good advice tho - ta
