Evga 680 cooling solution?
0tolerance
This will be my first water build/ trial and iw as wondering if anyone had any luck witht he new 680 chipset evga board.
Please list temps/ rigs and any suggestions you might have about what the best kit is.
I dont think ill do gpu right off the bat but i would like the option to add it later. And is that a good idea or should i just go all out?
Thanks for all your help
Z3r0
