EVGA 660 Ti FTW Question
clownshoes
Does anybody know if the EVGA 660 Ti FTW (P/N: 02G-P4-3667-KR) uses the 680 PCB and cooler like the 670 Ti FTW does? I can't seem to find any information or reviews on this particular card. Thanks
When you compare the pics, the housing and size are identical to the gtx 670 and 680 FTW cards. I find it highly unlikely that they would create 'copycat' cards without actually using the 680 PCB, however I can't tell you for certain that it is.
Thanks for the replies. Yeah, I looked at the specification sheets from EVGA on both and the dimensions are the same for both cards. The only thing that had me scratching my head a bit is that the back of the PCB is slightly different between the two. Thinking maybe I'll just pick one up and if it isn't on the 680 PCB I'll make sure I can return it.
