EVGA 512-P2-N757-TR
monkstah
Hello, I am upgrading my home pc for HD / digital DVRing and was wondering if anyone had anything good or bad to say about
EVGA 8600GT 512mb
It looks to be the perfect card for a home pc PVR system that can play games and be a little futureproof.. but want some opinions.
Its a great card for watching/making videos, and its an OK gamer card @ low resolutions (not past 1280x1024). Since you want it for the video stuff anyway, I'd say grab it :) You can also get the 256mb version for prob under $100 and they will perform the same.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130085
$89 AR ($20)
Edit again:
Also if you want to spend ~$150, grab the 8600GTS.
EVGA 8600GT 512mb
don't waste your $ on the 512m, get the 256m, Hardocp did a review comparing the 2, no difference in peformance
Get the one I linked above, its the non-OCed version thats DDR3. Saves you $10.
No can do. I've read reviews on that one. It is not HDCP enabled.
Just talked to EVGA, the only 2 8600gts they have with HDCP enabled on them are the 8600GT 256mb DDR2, and the 8600gt 512mb DDR3 ones. Model Numbers N757 and N752.
So between those two which should I get?
Well the other DDR3 won't either then, as its just a higher clocked version. Grab another brand if you want a 8600gt, or get a 8600gts since those all include HDCP. Evga is giving away the new Quake Wars game with their 8600gts, so you can always sell that if you don't want it and recoup some of the extra cost, or get XFX's which comes with Company of Heroes.
Evga: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130084
XFX: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150228
Edit because of your edit:
Don't bother with 512 ram, just get the 8600gts 256 vs 8600gt 512. All 8600gts come with HDCP while the 8600gt and lower are up to the mfg.
