Here's a thread for the new mATX SLi mobo by eVGA. Let's start this off right...
Here's where you can buy it: http://www.monarchcomputer.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=M&Product_Code=110826
Use this coupon code to save $30: P5XP-BW4LL4
Images from Monarch
Specsheet from Monarch
Images from Monarch
Manufacturer Part Number: 131-K8-NF44
At A Glance
* Support Dual-Core, Athlon 64 FX, and Athlon 64 939-pin Processors
* nVidia nForce 4 Single Chipset which supports 1000MHz HyperTransport system bus
* Accepts four 184-pin DDR modules - expandable to 4.0GB
* Supports DDR266, DDR333, and DDR400 in Dual Channel mode
* Two PCI IDE controllers support PCI Bus Mastering, ATA PIO/DMA, ULTRA DMA 33/66/100/133
* Four Serial ports provide 300MB/sec data transfer rate for four Serial ATA devices and offer RAID 0, 1, 0+1
* SLI: Two PCI-Express x16 slots (x8 effective bandwidth in each slot)
* One PCI-Express x1 slot
* 32-bit PCI slot
* Inegrated nVidia Gigabit LAN
* Onboard 8-channel AC'97 Digital Audio controller
* Micro ATX form factor
* Firewire 1394
* SPDIF IN/OUT
Additional Features
* nVidia SLI Technology
* nVidia RAID
* nVidia StreamThru Data Transport System
* nVidia Firewall Technology
* 64-Bit Architecture
* nVidia nTune Performance Application
* USB 2.0 Support
* Hyptertransport Technology
* nVidia Native Gigabit Ethernet
Dimensions
* Length: 9.75in (240mm)
* Width: 9.75in (245mm)
OEM Product
