I am hoping I am posting this is the correct area of this site.
We have three other pc's at home (two are Vista 32 bit, the other is XP), one xbox360, two Wii's, and one ps3. They all connect to the internet with a wireless connection.
I have two Cisco/linksys wireless routers that I have tried and the problem is the same regardless of which one I try to use. I have a WRT54GL and a WRT160NL. I have tried various firmware versions for both. Haven't tried any third party firmware though.
The problem is my pc listed in my sig. It is the only Vista 64-bit device we have in the house. The internet runs fine as long as my pc is turned off. As soon as I turn it on, none of the devices I listed have internet access any more (nor does the 64bit pc). As soon as I turn off the Vista 64bit pc the internet is fine for everybody else again. On the Vista 64-bit pc I have tried both hard wired as well as a wireless NIC's. Doesn't matter. I have tried putting in a static IP address as well as DHCP, neither makes a difference. Also, I installed Vista Business 32-bit on another hard drive for this pc and as soon as I did that my pc no longer took down the internet. It is obviously a problem with Vista 64-bit.
I have spent hours googling this. Apparently it is a common problem with 64-bit OS's and a lot of people are having this problem. So far I have formatted and reinstalled Vista on the pc in question to rule that out. I have disabled IPv6, turned down the speed on the NIC to 10mb Full Duplex, disabled wireless security on the router, install all updates to the pc as well as confirmed the router is on the latest firmware. Basically I have tried everything that I have come across as a possible solution and still no luck.
Unless someone has an idea, I will either switch to Vista 32bit or buy a new Netgear router. Apparently this is a known issue with Linksys/Cisco routers, and my previous Netgear router I never had any problems with until it died which is why I mentioned buying another one.
Any help would be greatly appreciated.
