Everythings Corrupt
undeadsac
Every-single-thing that I d/l onto my Maxtor is somehow corrupted. I can't install anything such as drivers etc. they won't unzip or unrar, theyre all corrupt, I can't watch any video the system BSOD infinite loop errors, I cant pass 3dMark05 I get BSOD IL, I can't play DOOM 3 or Half-Life 2, both crash at the boot screens, I basically can only use this computer for websurfing I so fucking tired of this shit I am about to scream.
See sig for comp specs
Try running Disk Error Checking Utility by Windows(think its more common by ScanDisk). Sounds like you have a bad sector in your hard drive somewhere. If that doesnt work, you can always try a full format of the drive.
Also, I think it could be the ram. If you have another computer, getting memtest86 might be a worthwhile expenditure of time.
Yes, what the first two said.
Schedule a thorough scandisk on your drive and also run memtest for at least 24 hours to track down where the errors are coming from.
I'd start from checking the memory...
You only need to run Memtest through about 3 loops to find any errors.
If you find errors check out each stick by itself.
Then try each pair and finally see if they will work together.
Also go to your hard drive makers home page and download a disk checker.
Luck........ :D
Luck........ :D
Already ran Memtest 86 passes all tests no problem.
Next steps would be an hour or two of Prime95 followed by the hard drive manufacturer's diagnostics.
Good Luck - B.B.S.
What the full BSOD error message including the STOP code ?
As it seems to be vid card related, as you stress that with games/3dMark it fails, hows the volts & cooling on it ?
Have you checked that your copy of DirectX is correct ?
Luck......... :D
Luck......... :D
I tried to use the DirectDiag and it fails the 3d render and puts the computer into BSOD Infinite Loop error involving the n4Disp drivers. I've tried 4 different driver sets and it has the same problem with all of them.
Check on how hot the vid card is getting.
Here's a page on the infinite loop error.
How well does that copy whats going on with your system.
There are some ideas to try in the bios at the bottom of that page.
Have you an old vid card, pref a non nvidia one, that you can try in your system.
Luck........ :D
What does it ?
It has various errors on Windows XP and a fewer on Windows 2000 with Nvidia driver NV4.dll.
* It causes computers to reboot.
* IRQ, Code 10; device won't start (device manager). (changing IRQ's by switching cards won't help)
* EventType: 0xEA - Thread Stuck in Device Driver Microsoft Q293078
* Graphic card trouble. The GeForce 1/2/3 and sortlike cards.
* Display trouble.
* OpenGL; spontaneous reboot, hardware lockup or insufficient virtual memory error from WinXP
* Direct 3D, Hardware lockup, BSOD with a message about an infinite loop error with a Nvidia driver
* BSOD error message - this varies but refers to a problem with "nv4_disp.dll"
* Error messages;
szAppName : Drivers.Display szAppVer : 10DE010110102E1102
szModName : nv4.dll szModVer : 5.1.2001.1240 Offset : EA4D06EA
or
BCCode : 100000ea BCP1 : FFA9D328 BCP2 : FFB2EF60 BCP3 : 81EA9788
BCP4 : 00000001 OSVer : 5_1_2600 SP : 0_0 Product : 256_1
* Blue screen with the message that the infinite loop is caused by NV4 DLL.
"The driver nv4_disp for the display device \Device\Video0 got stuck in an infinite loop. This
usually indicates a problem with the device itself or with the device driver programming
the hardware incorrectly. Please check with your hardware device vendor for any driver
updates."
* Causes instability on different systems.
thats it mang thats it!
every single thing that I d/l is corrupt on this system. There are no bad sectors on the HDD. Who wants to buy the whole system for 650.00?
See sig.
