Everything works except games?
spaceman
msi sli plat. mobo, 3200 winnie, xfx 6600gt, audigy 2zs gamer, 0cz pc3700 rev3 gold 2x512, ocz pc3700 platinum rev2 2x512, 74gb raptor. everything updated except the gpu bios.
prob is the game will load and play fine for a minute or two then have a c++ error and have to shut down? ideas?
It almost sounds like a bad video card. Its possible that it is rapidly overheating when you enter games (which would give you that minute delay). Try to track down a utility which logs the temps to a log file. Also check the System Log (Control Panel->Admin->Error Logs->System Log) to see if there are any errors reported.
RivaTuner has a temp-monitoring utility built-in, I'd suggest trying that.
What games are you trying? I've never heard of games crashing and reporting a C++ error and the culprit ending up being heat.
hmm weird b/c the card worked fine on an asus board but the msi no. will check riva temps.
can't even do that now. the game loads then before the screen comes on into the game the system rebooted with no error message after reboot.
if its having a C++ error it sounds like a compiling issue which would be the processor or windows install... is this a fresh windows install? are you overclocking your processor?
yes and no
xp pro fresh
no oc
cpu 2010 voltage 1.36-1.37
ddram is 167mghz
think it might be a bios issue? my asus sli mobo did the same thing with a pair 6800 ultras.
updated the bios and it went away. updated the msi bios and nothing. worked with an old xfx pci quadra but not the 6600gt. EVERYTHING but games works fine?
spaceman said:
yes and no
xp pro fresh
no oc
ddram is 167mghz
mghz?
run a prime95 tourture test. if it doesnt pass, you have issues with your chip.
Make sure your vid card has power plugged into it. That'll cause all games to die.
ran registry cleaner and it's all good? whatever lol
prob solved for now.
