everything put together... not powering up
noct3rn4l
I got everything finished and put together this afternoon, i had been waiting on figuring out how to get the fan onto my TRUE =] but after all was said and done... went to power up and no go.
Ive put 3 AMD setups together without any hitches so before i start RMAing things i thought id make sure im doing everything properly.
Hardware:
Enermax 600W NoiseTaker
Gigabyte EP35 DS3R
Q6600 + AS5 + Q6600 G0
evga 8600gt pci-e
audigy 2
realtek ethernet card
1 cd rom & 1 dvd burner
1 floppy
I installed the TRUE as instructed by ther website, using the black bracket behind the motherboard and then moving it to the case.. Though it still turns with all screws on as tight as possible (it doesnt lift or anything though) i feel safe thats its secure.
I plugged in all other components, and then went to power on, and nada. I dont think the ds3r has a power led on the board so theres no way for me to tell if its even getting any power.
I do have a question though. My PSU has 4 different power connections coming out of it.. one it 2x4; one is 2x2; one is 2x12 but comes apart into 2 separate pieces a 2x10 and a 2x2.
In my s939 it was it had the 12v and the 2x10 ATX connection... the intel board has the 12v and the 2x12 ATX connection... Is it correct to put the 2x10+2x2 together (they physically attach) and then use the other 2x2 (12V) by the CPU; this is what i did. the manual wasnt to much help and im feeling a bit like an idiot even asking this. But the manual says something like "NOT ALWAYS REQD" for the last 4 pins of the 2x12 (the part that unattaches).
i took some pics to help clarify but their from my cell phone so forgive the bad quality.
i wish i had an extra psu or intel c2d to try out but i dont.
[ http://img252.imageshack.us/img252/5251/comp3qv8.jpg ]
sorry you have to tilt your head =] but if you take a look, they actually attach and then the whole 2x12 piece fits in the ATX; and then theres a 12V by the CPU...
heres a closeup of how they attach
[ http://img220.imageshack.us/img220/7287/comp2xk9.jpg ]
and heres how it was plugged in before i came to my neighbors to cry on hardforum!
[ http://img220.imageshack.us/img220/8664/comp1tl9.jpg]
now on the other side of the mobo, theres also a 12V connection as well.
so nothing is even powering up, no fans, no nada
Yes, connect the 24Pin (the 2x10+2x2, never even seen it called that) Connector and the P4 12V (2x2) connector. That is correct.
Older motherboards only need the 20Pin connection, hence why the extra 4Pins are detachable. But all new motherboards today require the 24 pin connector.
Now reassemble the PC outside of the case, with the motherboard on the motherboard box. Start the PC by jumping (or connecting) the two power pins with a screwdriver. If the PC starts up, then something inside the case was shorting out the mobo. So look for a loose screw, standoff, wire, etc. Also make sure that the backplate of the HSF does not touch the case.
Also make sure that you actually placed the CPU in correctly.
yep im heading to the house to remove it from the case and try it without all my extra drives etc.
i highly doubt i put the cpu in wrong as i triple checked it before putting the TRUE on, but if it doesnt start up out of the motherboard then ill check again. I also checked as per the AS5 instructions and it was seated identically to the Quad core pics provided. But in the essence of thoroughness, if you take a look at this picture of the ep35 ds3r [ http://ucables.com/img/ipics/GIGABYTE-EP35-DS3R-MO-R36918.jpg ] from this angle, the yellow arrow on the CPU points to the bottom left corner and the notch in the top of the Q6600 fits into the slot in the top left corner of the cpu socket (relative to that picture angle).
You should get power to the mobo regardless if the CPU is installed or not. Yank out a speaker from another pc if your case doesn't have one.
You must have the case i/o connectors wrong. Even if your mobo or cpu or whatever is dead, your case will still come on (lights/fans).
did u try shorting the psu to come on without connected to the motherboard? google for paperclip trick
after a few days of tinkering i finally got everything working, im on the Q6600 right now =]
Now all i need to do is become familiar with gigabytes bios terminology!
Soon as i popped out my Audigy2 it started right up... weird as hell, and took awhile to figure out to!
Ill have to give that thread a glance in the morning, im falling asleep at the keyboard! =]
i installed cpuz 1.45 read quick though and for somereason it reads it at 1600 mhz and x6 multi even though bios says 333x9. CPU Vltg defaulted at 1.28375.... i did notice that my ram timings were unchangeable though (i think i remember hearing gigabytes have an unlock key command though)?
Thank god i dont have to listen to my Tornado anymore!
That's SpeedStep in action. It downclocks your CPU when it's idle or doing something that doesn't require too much CPU usage like web browsing. It'll clock back up when you run something CPU intensive like Prime95 or a game.
i think my wdd sata drive just died on me.. everything was up and running fine and then i started getting blue screens soons i installed java runtime 6... and since then i havent been able to get in windows (im at school now), it loads START WINDOWS NORMALLY SCREEN but then BSODs. I tried upping the voltage to ram/chipset/vid card +.1v thinking maybe it was a stability issue and i ran each stick of ram separetly to no avail. and sadly i do not have an extra sata drive to see if its an isolated issue.
I threw in the winXP cd to attempt another reformat but now it says that it doesnt detect/cannot access the disk drive. Ive tried disconnecting and reconnecting but it doesnt work. talk about luck.
im about to buy a 7200.10 or .11 today from newegg.... im thinking either 500 or 750 gb; what do you think, is the .10 better then the .11?;
.11 is faster.
Download and burn Western Digital's Data Lifeguard Diagnostics or Hitachi's Drive Fitness Test ISOs to a CD and run it. Should tell you whether or not that drive is gone.
i ordered a 500gb 7200.11 this morning; and picked up a wd 120gb sata from cc till it comes ;) unethical i know!
the drive was definately the problem. i installed without a hitch. no bsods, no errors while installing drivers, no write errors, nothing. And in the 1-2 hrs ive been playing around in windows ive already come love the q6600... theres nothing quite like downloading at 1.6MB/s; while ripping a cd; playing around on aim and converting a movie & installing office xp, all while opening and minimizing windows as if i were doing nothing.. i think im getting wet :)
LOL. Glad to see you're making good use of that CPU.
just did a little reading on that thread you posted earlier; im going to have to look at a cooling solution to the MCH.
What approach did you take? I must say, im very impressed with the Scythe Slipstream 110 CFM'er. It's so quiet i can sleep with the computer on now! itll be hard to get a fan onto it since my 8600gt slightly hangs over it.
Approach for what? Cooling the MCH or my CPU?
The MCH.
Also, rather then creating a new thread, I got my 7200.11 today :).... don't you just love receiving an order in less than 24hrs from the Egg?! :)
And as of right now I do not plan on running a RAID (2+ more drives), just the one 500gb. Should i set bios to AHCI to get 3 gb/s ? Or can that speed be achieved just by leaving it on IDE? I've never done ACHI before so I dont know if that involves any extra/new steps to do a fresh install or its just a change-and-go thing.
I read it supports NCQ, is that the way to go to see best performance?
Also, what do you think about partioning? 2x250s or 1x500?
