Everything opens with find
Kogun
So yeah, everything in windows opens with find now. All of the folders that is. Not exactly sure how this could have happen either. In explorer, all of the directories on the left column open fine, however, when not navigating from the left column in explorer, every folder that I attempt to open, just opens with find and the search results window. I tried messing with all the folder options - changing everything to the default. But that doesn't solve anything. There are two folders listed under the registered file types. File Folder and Folder. Under File Folder, there are two actions. "Find" and my camera viewer. Find is set as the default, which is maybe causing all folders to open with find? But I'm pretty sure I don't want my folders to be opening my camera viewer either. Folder, also has 2 actions: explore and open. I've tried switching back and forth between explore and open but nothing works. Maybe if I were to add the open action to the File Folder as well? But I don't know how to do that.
Damn you Windows.
