Everything is yellow tinted!
mrbay
So today I was fixing someone's computer, and I pulled the dvi monitor cable out from my video card. I used it for his computer, and after I was done, I plugged it back into my computer. (By the way, the computer was on the whole time) When I turned the monitor on, one of my DVI outputs doesn't respond, and the other one makes everything yellow. Any suggestions? This is getting really annoying. Thanks for your help.
my old monitor would yellow. endedup being the cable. If I bent it a certain way it would fix itself. Maybe thats it
Fixed it, got my flathead screwdriver and tapped all the pins. Seemed like it was a short within the wires, now everything is fine.
