Evercool
i cant wait to see kronchev's response to this.
id never buy that, if your wanting to buy a prebuilt kit, the only ones you should be considering are the koolance exos, corsair hydrocool, or zalman reserator or how
it is a clean package, sorta, but if you get this, dont expect to do much overclocking with this. it will certainly cool better than most aircoolers but aside from stock speeds it probobly wont hold up that much.
http://www.overclockers.com/articles953/index.asp
I would disagree with you acascianelli, the kits from Swiftech and Asetek both look very good (I'll know firsthand on the swiftech very soon), and the ones you listed, as you said, don't give very good performance.
no your right, they wont give as good performance as a swiftech or any other diy kit, but theyll perform better than the evercool kit he's looking at
