Evercool 120mm XP-120
Mysticcal
Is there anyway to mount an Evercool 120mm fan to an XP-120? I'm stumped... why did they make mounting this way! :(
there shud be 2 little hook liek attachments that slide onto the heatsink and hold the fan onto it..its in the instructions :p
Evercool fans are solid on the corners (so its 1 long hole). You may be able to stretch the clamp, thats how I got an 80mm fan on sum dinky heatsink.
If not, try cable ties.
