Ever use rubber gloves for putting computers together?
Crucible1001
Now I've never had a problem with ESD before and I always use my bare hands when touching computer parts. This has been for over a decade.
I happen to have some nitrile gloves laying around and was wondering if they would be useful in preventing ESD. I would probably wear them when applying AS5 at least. Would it really make a difference or should I just do it how I always have?
What makes you think that nitrile can't become statically charged? Plastics are not rubber, and you shouldn't expect them to be effective unless they're designed for that purpose.
They are nitrile rubber gloves. So yes, they are called rubber gloves. I use them for other reasons like cleaning the cat litter out or handling chemicals. If I don't need to waste them then I won't. So I was wondering why people who use those wrist things don't just use nitrile gloves. It would be cheaper and safer.
Nitrile is anti static and is used for this purpose sometimes. I asked about them because the only sources for anti static I can find are from some places selling them.
http://en.wikipedia.org/wiki/Nitrile_rubber
Well, I edited the post just a few seconds before you posted...
I wanted someone to confirm if they were anti static. I don't trust random shops on the internet for information. If someone has used them before, I would too without worry.
I don't think those gloves will stop a potential from forming, so if a charge builds up, it'll still spark when you take off the gloves and touch whatever it is.
I'm about to build my rig next week,I was thinking about set the case in a Swimpool table ( Plastic top with metal legs ) on a tile floor with rubber flip flops,is it safe ? :confused:
Wear mesh shorts and jersey, along with socks. Rub your feet across the carpet. Before you touch any computer part, setup the case on your desk and install the PSU. Plug the PSU into the wall, and keep the switch OFF. Now, walk around as much as you want, rubbing your feet on the carpet, just as long as you touch an unpainted, metal portion of the case while or immediately before touching any computer component -- and you'll be fine.
The people who assemble computers for the big OEMs wear rubber gloves. I had always assumed it was to keep fingerprints off the product.
Honestly, I wouldn't bother. I've been putting computers together for ten years now and never had esd problems.
I'm going to need to invest in a quality anti-static product in the near future. Where I live in the winter it's so dry and the temperature can get to (and surpass) -60 celsius. Anything, and everything gives you a jolt when you touch it, it's unavoidable.
Can anyone suggest such a product that will reduce the chances or eliminate the chance of destroying my computer when I need to upgrade. I've heard of some products, like the wrist straps and such, but is there anything you swear by?
Doing what Enginurd mentioned is just fine. If you're interested in a wrist strap, all it will do is make sure that you're always connected to the case. Any basic strap from RadioShack or somewhere similar will work just fine.
In case you missed my sarcasm... my clothing recommendations are some of the worst possible clothes you can wear since they build static so easily. I used them as an example to make a point: it really doesn't matter what you wear if you properly ground yourself before touching any parts (provided you don't move around while not grounded while holding the parts, lol). So, you can wear whatever you want, but to improve your chances of less static buildup, wear all cotton, hehe.
Oh, and make sure the wall socket you're plugged into is properly grounded as well (not old wiring of an old house that really doesnt have a ground). If you have a newer house/apt/whatever, then you shouldn't need to worry about this.
If you are really worried about ESD, just pick up a grounding wrist strap
or a grounded assembly mat
I own both and use neither.
They have esd wrist-straps and mats out there that are dirt cheap..
I worked at a tech-shop and we had both, but hardley-used them unless some big-wig came by to visit. The wrist-strap got in the way and was most annoying when you are working on x-amount of machines a day. The mat got tore-up after awhile because of the load of work we done on them.
At home, I have ceramic tile throughout my house, and I always work barefooted (static builds up slower). I work on my wooden coffee table because it's huge and has drawers with all my tools. I always touch the metal case to make sure I discharge myself.
A friend of mine uses a esd wrist-strap. He has it clipped to an old PSU that is connected to a wall-outlet. Reason is that it's constantly grounded through the 3rd plug. He has fried a couple components in the past and is paranoid about esd now.
If you are really worried about ESD, just pick up a grounding wrist strap or a grounded assembly mat...
LOL. BTW, an anti-static desktop mat (large) is only $12 at Fry's B&M. The small one is $8, but its the size of a keyboard, lol.
For serious ESD problems (sparks when you touch things) you should first of all try to improve the environment where you work on the equipment or move your work area to a better location.
A small bedroom humidifier may be all you need.
If that is not practical, then you should really use the wrist strap. They have the wire to bleed off the static charge. Simple gloves will not do that.
Another trick is to use a small amount of liquid fabric softener in a spray bottle of water and mist the work area surfaces (especially carpeting) before working.
Even with good precautions, a static laden environment will likely kill parts.
BTW they sell big packs of those blue nitrile gloves pretty cheap at Harbor Freight. I got 100 pairs for $8 one time.
I have never had an issue with static. I build my computers on my dining room table which is carpeted, and I'll walk over to the living room to grab a smoke or something. Just touching the PSU has always been enough.
As long as its plugged in.
