Darkstar850
- Feb 18, 2004
Ever finally had it with tinkering with your PC?
I mostly rebuilt my PC a few months ago. New processor, motherboard, RAM, case, fans. Basically kept the HDs, opticals, and vid card from the old machine.
My goal with my XP-M was 2.4 ghz. Despite getting what was considered the best or 2nd best stepping, the most I could get it to run stable at was 2.2. Many times while tinkering I would screw it up so it wouldn't post, and then I would have to reset the CMOS. Eventually I got it to run 2.4, but the volts it needed to maintain this speed were not justified by the sad excuse for a video card I am running, so back to 2.2 it went.
A few weeks ago I got some new memory to try out. Everyone on newegg was saying good things about its price/performance ratio.
Well, I was pretty busy at the time, so I just slapped it in, and left it running the same timings as the old RAM, 2-3-3-11. The manufacturer claims it'll run 2-3-2-5.
So tonight I decided I would get the timings where they should be. Rebooted the machine, went into the BIOS, and changed the timings. Saved the settings and...... no post.
Turned it off, waited, turned it back on... no post. Cleared the CMOS. Posted now. Went in and put the RAM timings back. Rebooted..... no post.
To make a long story short, I eventually had to put everything back to default (13.5X133, 3-3-3-11) to get stable. I eventually got it back to the way it was running at the beginning of my quest, at 2.2 with 2-3-3-11.
So at this point I am declaring ENOUGH! with this PC. It clearly doesn't want to OC, and it also clearly doesn't like me. Anyone else finally say ENOUGH! I am done @#%$ing with this machine? Got any good stories?
