So I've been in the process of putting together a HTPC. It's a little Habey 800B case with a ASRock E350-M1 motherboard running W7 64 bit. I havent had any issues with it while installing Windows or any of the misc programs (Office, MSE, XBMC, etc). But I recently turned it on in the morning and was going to let it run all day so that I could remote to it from work and work on it when I had a few free minutes. But when I got to work and finally got some time, it showed as being offline??? I figured that it had gone to sleep. So the next day I connected a monitor/keyboard/mouse to it, booted it and it showed that Windows had shut down unexpectedly. I selected the "Load Windows normally" option and then set the power options to "never" sleep. I attempted the same thing the next day, and again it was off when I tried to connect to it???
It took me a few days to get back to looking at it. After booting and messing around with it for a bit it seemed a bit sluggish and froze once, requiring a manual reboot. I checked the Event Logs and took as many screen shots as I could. I posted the screen shots below hoping that someone can give me some info from the Event log info.
Someone here at work suggested I search for the .dmp files to see if they would give any further info. Thanks in advance for any assistance.
This is the full text from the above User Profile Service error.
Also the last couple of times I manually rebooted, I got this screen???
