Event ID 51
DasFox
Well I was reinstalling XP, and during the install the power went out, so I'm not sure if this is the cause, or not but I think it messed up the drive.
Now I'm seeing a Event ID 51, saying:
An error was detected on device \Device\Harddisk0\D during a paging operation.
Looks like the drive might be bad?
THANKS
I would do a full (long) format off the WIndows XP install cd and go from there.
I did reinstall XP, samething. I have a WD Raptor and I grabbed the Lifeguard tools and ran the Quick test and Extended test and there where no errors, so the only thing to do is the 1s & 0s for a low level format.
With those first two tests showing nothing I get the feeling the motherboard got zapped during the power outage, but I have the darn thing on a nice APC surge protector.
I'm thinking I'll swap out the SATA cables, reflash the BIOS and then do a low level format and if I still have the problem and the low level format doesn't show errors I guess the board crapped on me then.
I also have Micro-scope:
http://www.micro2000.com/microscope_suite/index.php
I'll run some tests with that too.
THANKS
P.S. You think then possibly all it needs is a lowlevel format?
In my experience if a low level format doesn't fix it, it's toast. Yeah I would try it before I fired up all that other stuff.
Does your drive support NCQ? I read an article where disabling it helped solve a event ID 51 problem.
Microsofts website has some articles on it too.
Oh man I sure hope this is it, I have the nForce4 drivers installed:
http://www.nvidia.com/object/nforce_nf4_winxp32_amd_6.70.html
I had a look and it was enabled, but I thought I turned it off, because I always make sure that it is, I guess I forgot this time when I reinstalled XP.
http://img83.imageshack.us/my.php?image=screen1au.jpg
I don't see the message right now, oh MAN I sure hope this was the problem, I just built this box in Dec. and all I have been doign is fiddling with issues, I have not hardly enjoyed it since I owned it, and now this.
I sure hope this did it, I've been really bummed.
THANKS
P.S. Can you find that article again?
I had a similar problem with my Hitachi NCQ drive on my Ultra-D. The issue is with the NF4 driver, although it doesn't aversely affect performance, just throws arbitrary fits in the event viewer. I don't think you have a hardware problem.
Yes I reinstalled and reformatted my C: drive, all though I have a D: partition, not sure that this would of been effected too, but I didn't touch that.
As far as that MS Event ID 51 URL all I can make of it, is to just check with the vendor to see if there are any issues with the hardware in question.
As I mentioned I shut the NCQ and I have not seen this issue in the past 30mins, which I would of typically seen it already a few times, so far it's looking good.
Your original post made it sound like you were in the middle of an XP install when the power out.
Sorry for the confusion.
Yes I was, but then in the Computer Management I was seeing these errors, after I reinstalled. I also had NCQ enabled on the HDD, when typically I always turn it off, but forget this time, thinking this power outage was the issue, also, plus the fact I had diskeeper installed before playing with, thinking possibly the combination had mucked it up.
But 3 hours later after turning off the NCQ I have not seen the message again, so far looks like it was the ticket.
THANKS
Someone I know had this error (it appeared as though this was causing the system to freeze)
He sent it to me, but I could not reproduce the problem. I low level formatted, installed all drivers and did more stability tests. Everything was fine so I just sent it back to him.
I think he said it still freezes/BSODs, but I am not sure.
All I know is it wasn't a problem with the hardware, since it worked fine when I was testing it (computer was on for 3-4 days straight running tests constantly).
I wouldn't doubt it if it was just a case of PEBKAC for that guy.. :rolleyes:
i remember that ching... because my computer was doing the freezing thing too. i just bought a new harddrive and it hasn't happened since.
