EUE limit exceeded?
AMD_Gamer
one of my GPU clients just got a EUE limit exceeded pausing 24 hours
what is going on with that?
what do i do? just restart?
This means that the client EUEed multiple times in a row, and that you might have a problem with your setup. Has this client been running long before this started? Anything changed with the setup recently?
no it has been running fine for about a week
it has ended a few times with a strange error i forget what it was but it always continued on
Maybe something to do with this?
I just tried to download the new core now both of my clients have this problem wtf?
It's the new core that's the culprit.
how do i fix this?
There's no definitive fix yet. You can try running the shaders at stock speeds but some people reported that even that doesn't work. When running equipment at factory stress levels doesn't fix EUE problems, you know it's Stanford's fault and there's really nothing we can do about it but wait for a new core.
ok from the other thread i copied the 1.09 over my current files and it seems to be working fine now, back up and running at least, no EUE limit bullshit so far.
