archivalbackup
- Oct 12, 2007
Is there an ethernet WIC/HWIC that supports NAT for the 2811. I have one 4 port 10/100 card but it doesn't support NAT overload.
If I recall, you need T line code to run those. Might save you a headache since "sh diag" will say all is good
I never found a real use for NAT on a stick (e.g. NAT on a loopback as "outside" and hairpin back on the inside). Not sure of your requirements but maybe that could solve your problem if you've got limited interfaces instead of buying a new module. (Never tried it though, so don't blame me if it goes up in smoke)
