Ethernet port stoped working???????
TriPleThreaT
so a couple ah nites ago my comcast connection stopped,,, after some trial and error it turns out that my ethernet port on my asus motherboard has stopped working or burned out,,,cause i put in a new one and it works just fine and i can surf the net,,,,
so my question is,,, can a cable modem or comcasts service in anyway break or disable my onboard ethernet port,,,, my buddy is tring to blame it on comcast and im saying it just broke????
any help would be really cool...
thanks
I dought it is anything comcast did however any network is a giant loop begging to induct.
A nearby lightning strike or some other static charge could have done it.
Try going in to your BIOS and make sure that your PORT in not disabled. And if you can't find it in the BIOS reset it. And also make sure you right click on my computer go to properties and go to device manager and make sure the DRIVER for the ePORT is installed.
