maxpower1119
- Jun 4, 2004
The headline pretty much says it all. Is there any way to see the traffic passing through a router, specifically Linksys wrt54g (alread flashed with thibor). Thanks
moetop said:NOTE: I recently ran into a "hub" that was NOT a hub. It was a small linksys 4 port "hub" that when I tryed to use it to sniff I could only see broadcast and my own traffic. I had to get another HUB (this time 3 com) and then I could see all traffic. A true hub should send all traffic out all ports. I have no idea why linksys called it a hub, because it was obviously doing switching. That was sort of like buying a Lamborghini and calling it a Yugo. Made no sense.
bigstusexy said:Hrmmm... you do know the Ethereal/Wireshark supports remote caputre right? If your device will send out the data you can still capture it. wincap4 (and 3.4 I think, to some extent) supports this although it is still tricky in Ethereal/Wireshark and does require that you know the device name.
I'd go that route, or see if they brought back the syslog or SMTP traps.
