Here is my situation: We have 28 IP based camera's for a security system running off one server (Windows Server 2008). We have this server hooked up to our 48 port PoE switch that is only 100 Mbps. We have to turn down the Fps to around 12 Fps to accomodate the 100 Mbps switch (Cisco Catalyst 3560 switch I think).
Anyhow, I have 2 options:
1) Upgrade to a 1 Gbps switch
2) Utilize a Etherchannel setup
Option #1 isn't happening right now, since we don't own our gear and rent it from a vendor (Long story).
Option #2 is what I would like to try, but I've never done this before. Do I just need to install a second NIC and then get the switch configured properly for Etherchannel? Is there any special setup I would need to do in terms of purchasing the correct NIC or server side setup?
Any advice/comments would be appreciated. Thanks.
