ETH not showing
Sparky
Ethermine.org shows my balance however MyEtherWallet.com shows 0.
How do I fix this?
Are you sure your using the correct wallet address? Have you contacted MyEtherWallet.com with this problem?
Your wallet address doesn't exist in the ledger until some ETH is deposited.
Pools won't make that deposit until you have mined a minimum threshold
for a payout. Until then, your unpaid earnings exist only in the pool. Not on
the blockchain, not in your wallet.
Looks like your pool minimum is 1ETH, which could take a very long time.
Also appears you can change your minimum payout to 0.05ETH, which is
the setting I use. At my 175MHash/Sec get a payment about every two or
three days. Typical for one modest mining rig, plus a desktop.
I remember well the frustration of not being able to immediately backup
my first wallet, because it didn't actually exist yet. That sort of thing can
be real confusing, but is just a matter of patience and the correct settings.
I still haven't quite conquered how to get real dollars back out of it. First
need to open a disposable bank account to share with an exchange, so's
not to expose unnecessary access to my savings that I need to live on.
Seems I never get up early enough in the morning to go visit a real bank...
I found the setting at Ethermine.org and changed it. Now it shows in my wallet.
