ETA on DFI NF4 boards?
Specialist[X]
well i looked through several pages and i couldnt find anybody who posted a thread relating to this. does anybody an estimated time of arrival of the DFI NF4 Ultra/SLi boards? to be in stock i mean... and maybe possible prices?
Found this at the DFI forums: [font=verdana, arial, helvetica]
Angry_Games (Admin @ the DFI forums) said:
[/font][font=verdana, arial, helvetica]Availability date is still last week of Jan to March...its a loose time frame but I've been through this before with many companies (hardware mfg's and game developers are the worst at sticking to dates), so its a good estimate.
every place that offers pre-orders should be able to ship by the 25th of Jan...SHOULD is the key word here.
normal retail availability from newegg etc should be first week of Feb.
Does that help?
...my $0.02... :cool:
-DustMite-
edit: ZipZoomFly has DFI NForce 4 motherboards for pre-order.
the Ultra-D = $153 USD
the SLI-DR = $227 USD (at time of this edit)
[/font]
You can expect some pretty crazy prices. $300+ for the SLI, I bet. I'm going to buy one anyway, though.
Well, thats good news for me, I just bought 2x6800 ultras pci-e. I hope he is right, cause i dont' wanna get the Asus sli, I have seen way to many complaints about it.
A lot of the complaints are more with the BIOS, at least as far as my experience goes, it's use BIOS 1002, the last "final" BIOS and only be able to do a weak overclock, or use a beta BIOS and not have my NCQ SATA hard drives supported. For those without NCQ hard drives, they have been doing well with overclocks.
Having said that, to kind of play devil's advocate with myself even, if the DFI's are out late January like I keep on hearing for a possible ETA, then it's almost moot, I suspect that the next final BIOS, the one that (probably/hopefully) will both be a good OCing BIOS and one that supports NCQ drives won't be out until roughly then anyway. At best, the next final ASUS bios will be this week.
ZipZoomFly has the board listed but not in stock right now for $227.00 if that's any indication of price. No ETA listed, but I'd assume if they have at least the listing on their page, they at least think it's not much more then a couple weeks away.
They've had the Abit AX8 on there since at least the beginning of November, and it isn't out yet.
SLI SLI SLI...no ultra anywhere..makes you wonder..
Seeing the mass of posts about trouble with nforce4 SLI, one might think
the nforce4 isnt actualy "ready for market" realy.
I bet its going to take some additional time (2-3 Month) to make nforce4-MoBo`s
that have no "bug" issues anymore and can OC asmuch as you need to get a AMD +3000 (1.8MHz) to 2.4 MHz (high success-chance on a nforce3ultra)
MaMMa said:
What about the DFI 939 AGP boards?
Yep i'm wondering the same thing after spending $400 on a new 6800U agp video card just a few months ago. I'd like to jump to S939 but not with having to buy new video cards.
*shrugs*. If you aren't using NCQ SATA hard drives, you can do exactly what you're describing right now. The stability issues usually come down to either too weak of a power supply, or in my case recycling a 20 pin, switching to a 24 pin cured that. Okay, one has to use a beta BIOS to overclock well, and the betas don't support NCQ from what I've experienced, but 1002 does, so I'm assuming that the next final will have the overclocking features of the betas and the NCQ support of 1002. To me that's just the BIOS being a bit too iffy, not necessarily the actual hardware.
EDIT: Thought a bit about your comment, remembered the Anandtech article about making a NForce 4 Ultra work like a NForce 4 SLI. Remembered that basically, other then a minor hardware tweak, the chip was the same.
That, and well...there's been one SLI board in stock until very recently, and one Ultra board in stock, along with one NForce 4 non-ultra that is sometimes in stock. So, one of each chipset until recently, the Gigabyte SLI is just now showing up, and if you look at least at ZipZoomFly, they have BOTH a SLI and Ultra DFI board...and I think BOTH a SLI and Ultra MSI board, they keep changing the ETA on the two MSI's, but last I looked it was the 21st of this month.
So otherwise, your comparsion of "no ultras", makes no sense, when there's been one Ultra chipset board in stock (A Chaintech), a NForce 4 non-ultra (A Gigabyte) and a couple of both SLI and Ultra boards just around the corner. :p
Well, I was speaking generally. :p GENERALLY speaking if they add a product, at least when they initially add it the product is only a couple weeks away. Yes, I've seen them add something, give an ETA a couple weeks away, then when that ETA hits have them add a few days to the ETA, but I'd assume they are going on the information they had at the time. Otherwise, when they initially added the Abit AX8, I suspect they did initially have something like an Early December, '04 ETA given to them, even if they never posted an ETA on their website.
I don't know...but based on how they have acted previously, this would seem to be the case.
