I ran into an issue a few minutes ago with running DD-wrt x86 in ESXi.
What I did, was use the VMware standalone converter to convert my DD-wrtx86 Workstation VM to an ESXi VM.
All of that went well, however, I could not get the DD-wrt ESXi VM to see the WAN of the modem.
Usually, with my workstation VM of DD-wrt, I disable all protocols for the NIC I added thats connected to the modem, except the VMware Bridge protocol. And bridge it to VMnet4 in the Virtual Network Editor.
And works, it passes what the modem sends to the NIC directly to the DD-wrt VM. It gets the IP address and everything from the modem. (this is the 1st NIC that dd-wrt sees, and sees it as WAN)
And then the built in NIC of the motherboard is bridged to Vmnet1 in Virtual Network Editor, and is left alone protocol wise and is connected to a physical switch. (this is the 2nd NIC dd-wr sees) From there, it acts just like a hardwired router. Perfectly. It does take the Windows 7 host a few extra min to get an IP, however everything connected to the physical switch gets served quickly.
Ive set it up similar, or so I thought in ESXi, the DD-wrt x86 served out DHCP perfectly to virtual and physical hosts via the built in NIC. But as I said, the 2nd NIC thats connected to the modem, DD-wrt X86 isnt seeing WAN side.
So, I guess I either need to somehow "bridge" the 2nd NIC thats connected to the modem on the ESXi host to the DD-wrt x86 VM, or Direct pass the 2nd NIC to the dd-wrt ESXi Vm?
My ESXi host doesnt support DirectPath unfortunately.
And from what I can tell here:
Im feeding the modem directly to a virtual switch, instead of the DD-wrt X86 VM in ESXi?
Is there a way to around that?
:edit: Right now it disconnected because I switched back to Workstation to get my internet back.
