Has anyone managed to get this to work?
I've tried two different setups, both which don't work.
Setup 1:
Intel i5 2400 (with VT-D)
Gigabyte P67A-UD3R-B3 Virtualization turned on
8GB DDR3 ram
ESXi 4.1 & 5 install fine. However report this error:
http://img195.imageshack.us/img195/5746/97654009.png
Setup 2:
HP 3300MT Virtualization turned on(It specifically shows VT-D as turned on as well)
4GB DDR3 ram
ESXi 4.1 & 5 install fine. However report this error as well:
Am I missing something? I was under the impression that as long as I had a VT-D capable CPU and virtualization was turned on in the bios it should work? Especially with the HP computer as it shows VT-D specifically.
Any help would be appreciated... I'm bashing my head on the wall here.
I have also tried it on a socket 775 computer with a Intel Q9400(same result)
Setup 1:
8GB DDR3 ram
Setup 2:
4GB DDR3 ram
