- Feb 8, 2005
While creating a snapshot of a VM, can you continue using the VM? I only ask because it seems to take about 15 minutes to make a snapshot, and I like to have multiple snapshots for each VM... If I have to wait 15 minutes between each, it's gonna take all day to configure a single server.
Example:
Fresh install
Snapshot
Windows Updates and basic configuration
Snapshot
Programs/Roles install
Snapshot
Programs/Roles configuration
Snapshot
That's an hour in snapshotting alone... I did notice that I can still use the VM, but will it screw with the snapshot if I do? For example, if I just finished a fresh install, click the "Take Snapshot" menu item, and immediately start downloading and installing Windows Updates, will the snapshot be of the VM prior to the updates, somewhere during, or after?
Example:
Fresh install
Snapshot
Snapshot
Snapshot
Snapshot
