ESXi newb question, Guest Memory missing information?
jonnyjl
I'm running ESXi 4.1u1, under a VM's Resource Allocation tab, under Guest memory the only thing I'm seeing is Active.
I thought it's supposed to show Ballooned, Private, Shared, etc etc. Do I need to turn something on?
Do you have virtual center?
Sorry, should have specified, it's free (@home).
The literature is confusing. I really need to pull up that chart on the differences between the free version and the paid ones.
So I'm guessing this just is another not available options.
