LightningCrash
- Dec 29, 2000
Hi guys. I had a problem this weekend and I want to try to get some troubleshooting ideas before I give it another go.
Host: ESXi 5.5u1
Mobo: Supermicro X7SBE
NIC: Intel® 82573V + Intel® 82573L (Yes I had to roll that in to 5.5)
Old Modem: Moto SB5121
New Modem: Moto SB6121
Guest: Sophos UTM 9
Guest try#2: CentOS 7
I have a vSwitch configured for the RED interface, using the second NIC. It is dedicated to the cable modem and the UTM VM.
On the SB5121, everything works just fine.
When I switch to the SB6121, and the modem is provisioned, the UTM VM doesn't get a DHCP offer.
Before the modem was provisioned, I got a 172.x address and the ISP captive portal "Please call us to configure your modem."
I can plug the SB6121 into my laptop and it works just fine. Plug back into the ESXi host, no joy.
I ran tcpdump on the VM and I see a dhcp request go out on the vnic, but it never receives a response. I swapped in a CentOS 7 VM and got the same issue.
I restart the modem after almost every VM or host change.
What I have tried on the ESXi side:
I'd like to get some recommendations for things to try on the next go around, which might be this weekend or so. Any ideas?
My to-do list so far:
Thank you in advance for your ideas.
Host: ESXi 5.5u1
Guest: Sophos UTM 9
- Restarting the ESXi host
- Restarting the VMs
- Tried out a CentOS 7 VM on that interface
- Monkeyed with promiscuous mode on the vswitch and port group.
- Set the MAC of the VM VNIC to be the MAC of the physical NIC
- Moved the VM's second VNIC temporarily to the inside LAN, which got an IP from DHCP.
- Bug the cable company more about it (I got the captive portal page, so I got DHCP once, right?)
- Throw a guad GbE NIC in a machine, make a bridge from 2 ports and run tcpdump on the interfaces.
- Use a quad GbE NIC in the ESXi machine instead of the unsupported onboard NIC (doubt this will help but it's trivial to try)
