MacModMachine
- Nov 26, 2010
Basically planning a rebuild of my old ESXi home system.
I currently have a micro ATX DQ77KB , 3470S Quad i5 , 16gb ram.
my new system i have ordered these new parts
Intel S5520HC with dual quad E5520's
Supermicro CSE -745 case (dual 920w)
Dual M1015 IBM HBA's
Dual intel 1000/PT's
6x4gb ibm 10600mhz sticks ECC
Questions on my build are the supermicro case only has 1 8pin and 1 4pin , the motherboard requires 2 8pin for the cpu's now can i just 1 4pin on the 8pin (all the rails are joined on the 8pin + and - ?).
the dual 1015's . will i have any issues running 2 of those ? (no experience with those brand of controllers)
the ram for these boards , is it very sensitive for speeds ? , i know desktop boards you can usually shove just about any ram of the type it takes ddr2,ddr3 and i will usually just run at the max speed the ram can do. I bought 4gb 10600mhz cl9 , which the board supports in other brands just not the particular micron one i bought.
The virtual machines i use for now are
unRAID passthrough 1 of the 1015m's (runs 8 disks)
Windows 8.1 for simply accounting and my esxi backup
Windows 2012 R2 for testing and certifications
4 turnkey disto's for various things
OSX 10.9 (development)
OSX 10.8 (Testing and support for some of my clients)
im very caught up on storage , what is recommended ? ssd's ? storage pools with zfs?
sorry for the long 1st post , thanks for any input.
