Today about 8:47 AM by ESXi has been booted. Question is why ?
Why I can see so much strange firewalls changes... ?
Cannot login root@10.10.134.100
error
4/2/2014 7:07:52 PM
root
An account was updated
info
4/2/2014 7:07:22 PM
esxi.olivia.net
pwojtachnio
User pwojtachnio@ logged out (login time: ,
number of API invocations: , user agent: )
info
4/2/2014 6:56:00 PM
pwojtachnio
User pwojtachnio@10.10.134.100 logged in as
info
4/2/2014 6:50:20 PM
pwojtachnio
WXP-P2P (10.10.134.x) is powered on
info
4/2/2014 6:47:11 PM
pwojtachnio
Message on WXP-P2P (10.10.134.x): There is at
least one virtual SCSI device installed on this
Windows XP virtual machine. Windows XP does
not include drivers for the BusLogic SCSI adapter
that VMware ESX uses for virtual SCSI devices.
To use these virtual SCSI devices, install the
VMware driver in the virtual machine. Download
the driver from "http://vmware.com/info?id=43".
info
4/2/2014 6:47:11 PM
pwojtachnio
WXP-P2P (10.10.134.x) is starting
info
4/2/2014 6:47:10 PM
pwojtachnio
info
4/2/2014 6:45:58 PM
pwojtachnio
Cannot login pwojtachnio@10.10.134.100
error
4/2/2014 6:45:40 PM
pwojtachnio
User dcui@127.0.0.1 logged in as
info
4/2/2014 8:50:01 AM
dcui
SSH access has been enabled.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
The DCUI has been enabled.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
The ESXi command line shell has been enabled.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
No scratch partition has been configured.
Recommended scratch partition size is {} MiB.
warning
4/2/2014 8:49:23 AM
esxi.olivia.net
At least one coredump target has been
configured. Host core dumps will be saved.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
Port vmk0 is now protected by Firewall.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
Physical NIC vmnic1 linkstate is up.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
Physical NIC vmnic0 linkstate is up.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
Firewall configuration has changed. Operation
'enable' for rule set ipfam succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set ipfam succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set rabbitmqproxy succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set rabbitmqproxy succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'setrequired' for rule set vsanvp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set vsanvp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vsanvp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set cmmds succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set cmmds succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set rdt succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set rdt succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vprobeServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set remoteSerialPort succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vSPC succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set WOL succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set WOL succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set IKED succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set syslog succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set DVSSync succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set DVSSync succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set DHCPv6 succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set DHCPv6 succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set DVFilter succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set gdbserver succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set httpClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set httpClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set ftpClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set HBR succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set HBR succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set NFC succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set NFC succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set activeDirectoryAll succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set activeDirectoryAll succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'setrequired' for rule set vSphereClient succeeded
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set vSphereClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vSphereClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set vMotion succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vMotion succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set webAccess succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set webAccess succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set faultTolerance succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set faultTolerance succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set updateManager succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set vpxHeartbeats succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set iSCSI succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set CIMSLP succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set CIMSLP succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set CIMHttpsServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set CIMHttpServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set ntpClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set snmp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set snmp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set dns succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set dns succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set dhcp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set dhcp succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set nfsClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set sshClient succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'setrequired' for rule set sshServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'enable' for rule set sshServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
'add' for rule set sshServer succeeded.
info
4/2/2014 8:49:23 AM
esxi.olivia.net
User root@ logged out (login time: , number of
info
4/2/2014 8:47:47 AM
root
Lync Server (10.10.134.x) is powered on
info
4/2/2014 8:47:37 AM
root
Lync Server (10.10.134.x) is starting
info
4/2/2014 8:47:37 AM
root
W2k12r2-SRV (10.10.134.x) is powered on
info
4/2/2014 8:47:27 AM
root
W2k12r2-SRV (10.10.134.x) is starting
info
4/2/2014 8:47:27 AM
root
W2k3-Terminal-SRV (10.10.134.x) is powered on
info
4/2/2014 8:47:17 AM
root
W2k3-Terminal-SRV (10.10.134.x) is starting
info
4/2/2014 8:47:17 AM
root
User root@127.0.0.1 logged in as
info
4/2/2014 8:47:12 AM
root
vGW-Vyatta-01a (10.10.134.254) is powered on
info
4/2/2014 8:47:07 AM
root
vGW-Vyatta-01a (10.10.134.254) is starting
info
4/2/2014 8:47:07 AM
root
info
4/2/2014 8:47:07 AM
root
Host has booted.
info
4/2/2014 8:47:06 AM
esxi.olivia.net
info
4/2/2014 8:47:04 AM
root
'enable' for rule set CIMHttpsServer succeeded.
info
4/2/2014 8:47:04 AM
esxi.olivia.net
info
4/2/2014 8:47:04 AM
root
info
4/2/2014 8:47:04 AM
root
'enable' for rule set CIMHttpServer succeeded.
info
4/2/2014 8:47:04 AM
esxi.olivia.net
info
4/2/2014 8:47:04 AM
root
info
4/2/2014 8:47:03 AM
root
'enable' for rule set vpxHeartbeats succeeded.
info
4/2/2014 8:47:03 AM
esxi.olivia.net
info
4/2/2014 8:47:03 AM
root
