A Great friend to the HardForum with a great kid that he is trying to get a scholorship to continue his schooling. Please give hime a vote! Only 24 hours left! Thanks.
Sorry, forgot to mention it has a PS2 keyboard only. I tried to use a USB keyboard and its the same. The is a IBM BR10i card (Flash to LSI IT firmware) on the PCI-E slot without any HDD connected to it yet.
MB - X9SCM-F
Memory - SuperTalent 4 Gig Module X 4
Processor : Intel Xeon E-1230
Power Supply: Antec Neo 620W
SSD: Crucial C300 64GB on onboard SATA III
Hmmm, I have an x9scl-f (almost the same) with the same CPU and had no issues. Then again, I was installing from a sata optical drive. Try some of the suggestions from here:
Sounds like something flaky with the cd or the usb optical drive. Can you borrow a sata optical drive and try again? Or maybe try to install from usb stick?
1. There is something wrong with the 82574L Ethernet Controller after BIOS update to 1.0b.
2. Running any latest live CD Desktop (fedora 15) hang during start up
3. Same as ESXi boot CD (hang at Loading HID)
4. If I disabled the 82574L controller, fedora 15 will boot up fine.
5. ESXi boot CD will boot until the Accept License screen but error out with "cannot load vmfs3 module" (Message is misleading, as this is due to ESXi cannot find any Ethernet controller on the MB. 82579 is not supported at the moment.)
6. I than reset the BIOS back to defaults and that seems to resolve the issues with the 82574L Ethernet controller. I can now see both Ethernet controller in fedora 15 and ESXi can at least see the 82574L Ethernet controller and does not throw the "Cannot load vmfs3 module" anymore.
see that other thread by Chilly, http://hardforum.com/showthread.php?t=1607992, to get that 82574L NIC working in ESXi. my x9scm-f is humming along with both onboard NICs recognized and usable 1by ESXi. let us know if you having problems with the oem.tgz swap!
